alan.whelihan | -- 12-22-2013 @ 10:53 AM |
Is it possible to repair transmission case scoring/damage by the countershaft thrust washers spinning?
juergen | -- 12-22-2013 @ 1:44 PM |
Is the wear even? If so I suppose you noticed it when the clearances were out of spec. An old trick to tighten clearances was to shorten the cluster (in a lathe) and add another thrust washer or even an 8M-7129 washer.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6839 |
