haysmo | -- 12-21-2013 @ 11:59 AM |
I have removed the 6 screws that hold the metal panel. I have raised the panel up and out. Do the 4 screws that hold the crank have to be removed, or how do I get the glass out of the channel?
tommorookian | -- 12-23-2013 @ 1:57 AM |
HELP! Are you talking about the rollup rear window or the door window? Either one, to get the glass out of the channel, soak it in transmission fluid for a day then gently tap a razor blade (use a wood block) around both sides, maybe soak another day and tap again.
haysmo | -- 12-23-2013 @ 6:01 PM |
Thank you, Your method with the trans fluid, razor blade, and wood block worked perfect.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6838 |
