6lucky13 | -- 12-12-2013 @ 4:48 PM |
How do I center the steering wheel on my '36? With wheels pointed straight, it is off about 1/8 turn.
supereal | -- 12-12-2013 @ 7:13 PM |
Adjust length of the drag link, the connection between the arm on the steering box and the axle connection.
40 Coupe | -- 12-13-2013 @ 4:04 AM |
If you have the original style 36 drag link. You will have to remove the tie rod end from the steering arm and loosen the one clamp turn the tie rod end it in or out of the drag link. If you have the 1941 drag link it has an adjustment sleeve with two clamps loosen the clamp bolts and turn the sleeve without removing the tie rod end for adjustment.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6811 |
