Bill S | -- 12-11-2013 @ 8:47 AM |
I am looking for wiring diagram for my 46 heater switch.
4dFordSC | -- 12-11-2013 @ 9:27 AM |
Found this on an old thread. Hope you can read it.
TomO | -- 12-11-2013 @ 11:09 AM |
Bill, Which heater do you have? The manifold heater or the 3 door hot water heater. This is for the 3 door hot water heater: if you are installing a new harness, the harness should come with the correct diagram. If you are just trying to replace the switch, follow the colored dots on the switch, brown wire goes to the brown dot, yellow goes to the yellow dot, etc. Tom This message was edited by TomO on 12-11-13 @ 11:11 AM
Bill S | -- 12-11-2013 @ 11:23 AM |
Thanks for the help. Just what I needed.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6807 |
