Mustangman | -- 12-07-2013 @ 12:34 PM |
Has anyone installed a cruise control in a 40 ford?
ford38v8 | -- 12-07-2013 @ 3:22 PM |
Of course, you're thinking of using the one off your old Mustang? Alan
tommorookian | -- 12-08-2013 @ 2:51 AM |
I used a Rostra on my 36. Works great. Wiring it up was a little confusing. The dipswitch setup was a bitch but, when I finally got to talk to the technical guy it got real easy. turn #1 on, turn everything else off. They give you a lot of adapters to add to the linkage but I still had to make on doohickey myself.\ http://www.rostra.com/universal-aftermarket-cruise-control-by-rostra.php
Old Henry | -- 12-08-2013 @ 11:51 AM |
Doesn't the 40 have a throttle knob? That's what I use for "cruise control" on my 47. Old Henry (The older I get, the better old looks.)
supereal | -- 12-09-2013 @ 9:56 AM |
Most aftermarket cruise controls require an open driveshaft to allow magnets to be attached for the speed sensor. That leaves out cars and pickups with torque tubes.
42merc | -- 12-09-2013 @ 12:20 PM |
The Rostra brand cruise control offers a signal generator that fits inline with the speedometer cable. No modifications required.
TomO | -- 12-10-2013 @ 9:03 AM |
I use the cruise control on my modern car to keep the lead footed driver from speeding, but the engine sound keeps me from doing that in my 40. Tom
1934 Ford | -- 12-10-2013 @ 5:32 PM |
Old Henry is right! That's the same cruise control as the 1934 Ford. Question: Why would we want to use it that way? I enjoy the art of hearing and adjusting to the flat head's work load. It's part of the fun of drivng old cars. 1934 Ford's since 1972
Old Henry | -- 12-11-2013 @ 5:54 AM |
On my very long road trips I get ankle, foot, leg fatigue/cramps. Before I got my throttle working I'd switch and run the gas with my left foot for a while that was bit awkward. I don't use the throttle on short trips around town except to keep the rpms up at stops to keep the generator charging. Old Henry (The older I get, the better old looks.)
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6793 |
