murphy1936 | -- 12-06-2013 @ 5:17 PM |
What size wire on plug wires should I get, and how to test wire other than spark testing. I would like to use multimeter if possible. Thks john
joe b | -- 12-06-2013 @ 5:31 PM |
Why not buy a set ready made and authentically colored? Not being critical. Just curious.
murphy1936 | -- 12-06-2013 @ 7:44 PM |
Good point Do you know who I should go to please? John
ken ct. | -- 12-07-2013 @ 2:18 AM |
Cole's Ign. Rochester,ny. 1-585-342-9613 9 to 5. ken ct.
joe b | -- 12-07-2013 @ 7:00 AM |
Any early Ford parts supplier will have them. C&G, Mac's etc.
supereal | -- 12-07-2013 @ 12:07 PM |
Use only the wire type cables, not the carbon fiber type. Solder the terminals on both ends of each cable firmly to the conductor. When we get a vehicle with a problem such as a miss under load, almost always it has the non-metallic cables or a loose terminal.
murphy1936 | -- 12-07-2013 @ 1:52 PM |
Thk you for vendor info john
supereal | -- 12-09-2013 @ 10:00 AM |
I'm not sure why posting sometimes results in multiple messages. It seems to be more frequent lately. I realize that often the site is busy and delays response, but the above multiples resulted from just one press of the button. Using an IPad or Iphone can cause it more often than a real computer, but not always.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6788 |
