j.grif | -- 12-02-2013 @ 10:31 PM |
Collecting parts for clutch assy and wondering if a new nine inch disc that I have would be ok on a ten inch pressure plate?? And why some flywheels of the same size have different bolt hole spacing, maybe for different size pressure plates?? Thanks for the help.
kubes40 | -- 12-03-2013 @ 5:49 AM |
NO to a 9" disc with a 10" plate. NO! They must match!!! Yes to the holes being drilled and tapped in different locations on different flywheels. Bigger plate requires a larger bolt diameter.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6780 |
