murphy1936 | -- 11-21-2013 @ 7:00 PM |
Have one on recent purchase. I'm completely lost as to how it works and if it needs maintenance of some kind thks john
supereal | -- 11-22-2013 @ 3:56 PM |
I have never seen a magneto ignition on anything other than a specialty car, such as a dragster. While mags are common on aircraft that operate on a steady rpm basis, I can't imagine such a setup on a car for the street. Keep us informed on this unusual conversion. I'm a great fan of the stock Ford ignition, as it has proven to be "bulletproof" for decades. My last encounter with magneto ignition was with Farmall tractors!
murphy1936 | -- 11-22-2013 @ 8:58 PM |
Will keep you abreast. Right now car came with battery undersized and it was basically note nought to start car. Trying to debug. John
murphy1936 | -- 11-24-2013 @ 10:12 PM |
Ok according to what I found on discussions for which I am grateful is I do not have magneto set up but a conversion to Mallory distributor having a coil and pts. A magneto set does not have a coil. Boy am I getting educated. Now if she will only start up. I'm in process of checking plugs for spark.. Coil sparks ok not as snappy as I would prefer.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6739 |
