jimbohoh | -- 11-10-2013 @ 12:11 PM |
I am having trouble determining if the rear fender welting follows the body down to the bottom rear of the fender or goes across the top of the gas tank cover and continues all the way to the other side running board? I have seen pictures of it done both ways and want to make sure I do it right. If it goes across the gas tank cover then it would have two short pieces on each fender to the bottom. Any help you can give will be greatly appreciated! Thanks, Jim
ford1ford | -- 11-12-2013 @ 11:43 PM |
Try Roy Nacewicz Enterprises--http://fordscript.com/--you can call him up and speak to him,He makes the welting right there. Just installed my order looks good
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6699 |
