Frosty | -- 11-02-2013 @ 10:58 AM |
Is there a source for pre-bent gas lines for these cars? Tank to carb?
ford38v8 | -- 11-02-2013 @ 12:34 PM |
Frosty, The original copper plated rolled steel fuel ines are still being made by the original manufacturer in Michigan, and are available from many sources, but I like the service and attention to detail you get from Roy Nacewicz. You'll get your tank to pump line in a large coil, and the pump to carb line will be pre-bent for your application. Roy Nacewicz Enterprises www.fordbolts.com Alan
Frosty | -- 11-02-2013 @ 5:30 PM |
Thanks ford38V8
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6678 |
