ckh | -- 10-28-2013 @ 10:39 AM |
Does anyone have any experience or thoughts on the use of shim packs on the main bearings on a 21 stud babbit main block? The gentleman that poured the bearings in my block installed them. I haven't assembled the engine as yet and am having second thoughts about their use. I am concerned about oil leaking from the rear main into the clutch/flywheel area. Regardless, one of the shims for the rear main cap is broken and I will have to find a replacement should I decide to use them. It would probably be difficult to find. Would it be possible to remove the shim packs and re-align bore the bearings or would re-pouring the bearings be required? Would appreciate anyone's thoughts on this, especially experienced engine builders. Thanks This message was edited by ckh on 10-28-13 @ 10:49 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6665 |
