StewyQ | -- 09-30-2013 @ 8:15 PM |
Hi I can not find any information on which way up the bearing goes when assembling the king pin in the spindle. does the part of the bearing that turns go up against the axle and does the shims go under the tin bearing casing. just pull my 39 front axle apart to replace bush's and pins and one bearing was up and one was down. Thanks for your help Stewart. New Zealand
40 Coupe | -- 10-01-2013 @ 4:25 AM |
Here are instructions for the 39. https://www.speedwaymotors.com/images/pdf/910-32121.pdf
StewyQ | -- 10-01-2013 @ 10:18 PM |
Thank you 40 coupe, you may be interested I have bought the 5th new 40 Ford coupe made by Real Deal Steel,they put them together for Dennis Carpenter, I am changing the windscreen to 39 so it will be a 39 deluxe. regards Stewart Quertier New Zealand
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6569 |
