39topless | -- 09-15-2013 @ 3:30 PM |
Great info for Larry on his '36 rumble seat step pad locations and parts list. Would anyone have the same type of info for my '39 rumble seater? Thank you. Phil
40 Coupe | -- 09-16-2013 @ 1:02 PM |
See page 2-10 of the 38-9 restoration book. Two stamped steel brackets, using the 48-714028 convex washers and mounted with a bolt. The brackets have rubber pads between the fender and brackets.
39topless | -- 09-16-2013 @ 2:17 PM |
Thanks, I guess I should have looked there first. Duh. Is there anyone that makes a repop bracket that you know of? Thanks so much. Phil
40 Coupe | -- 09-17-2013 @ 4:01 AM |
I have not seen the bracket reproduced, or the special washer under the fender. The washer is convex on one side only, flat on the other. I believe the earlier brackets 37-38 are cast and not stamped. You may want to check this. This message was edited by 40 Coupe on 9-17-13 @ 4:02 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6527 |
