coftbird | -- 01-18-2010 @ 6:37 PM |
My 37 pickup has 39 hydraulic brakes. I need front brake drums. It appears that 36 drums will work although they ride inside the backing plates rather than over the backing plates. Would I be causing any problems using the 36 drums? Thanks for any advice. Charlie
G Tosel | -- 01-18-2010 @ 10:23 PM |
The 36 and 37 brake drums are not interchangeable. Offset of hub and backing plate will not work. I have a 36 Ford and needed 37-39 front drums for wide five bolt pattern to use hydraulic brakes. Rear 36 brake drums will work with hydraulic conversion. Thanks Gary Tosel
coftbird | -- 01-23-2010 @ 5:08 PM |
Thanks for the info Gary. So I am now looking for 37-39 front brake drums. If anyone can help, coftbird@yahoo.com. Charlie
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=646 |
