j.grif | -- 08-22-2013 @ 3:32 PM |
Trying to get a good deep sound out of the muffler on my 36 coupe. Installed a used smithy muffler and sounds good (to me) but connecting the 1&1/2 inch tail pipe and it quitens down too much for what I wanted. So was wondering if a larger diameter tail pipe would keep the rumble that the muffler makes?? Appreciate suggestions , Thanks
trjford8 | -- 08-22-2013 @ 5:31 PM |
Do you have duals or a single pipe? Duals with a nice set of 24"glasspacks will get you the sound you want. Duals on a '36 are a little bit of a challenge due to the location of the battery box, but it can be done.
j.grif | -- 08-22-2013 @ 8:56 PM |
Only a single exhaust on the coupe. We do have a 36 sedan with duals and it does sound good. Something to think about.
TomO | -- 08-23-2013 @ 7:14 AM |
A 2" pipe will allow more sound at the back, but I doubt if it will give you the sound that you enjoy from your duals. Go with a shorter glass pack muffler and keep the 1 1/2" tail pipe. Tom
JM | -- 08-23-2013 @ 10:59 AM |
The muffler went bad on my original '35 fordor sedan. While looking for an original type replacement muffler, I decided to temporarily put in a straight section of pipe. That was about three years ago. The sound is great as far as I am concerned. John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6441 |
