houseof34s | -- 08-05-2013 @ 10:25 AM |
will a 46 rear differential work as a replacement for a 40 tudor??? houseof34s
kubes40 | -- 08-05-2013 @ 1:49 PM |
If you're replacing the entire rear axle assembly (housings, etc.) then you need to know the '46 is about 3/4" wider than the '40. Still, no problem. Use the '40 radius rods with the 46 rear. Place about 5/16" spacer between each rod and axle housing (two places per side) and everything will line up well. That additional width (about 3/8" per side on the car) is hardly noticeable.
houseof34s | -- 08-05-2013 @ 2:18 PM |
will there be any problem when connecting spring shackels?? >> Thanks << houseof34s
kubes40 | -- 08-05-2013 @ 5:55 PM |
The '40 shackles can be used. You'll need to stretch the spring a bit further of course. I have made this swap a number of times. Usually it's for a guy with a later Columbia that doesn't want to spend the money to get the proper '40 overdrive...
houseof34s | -- 08-06-2013 @ 6:51 AM |
Will the40 torque tube and drive shaft connect-up mate-up ok? >> Thanks << houseof34s This message was edited by houseof34s on 8-6-13 @ 6:53 AM
kubes40 | -- 08-06-2013 @ 2:32 PM |
The 40 torque tube and drive shaft can easily be installed to the '46 rear assembly.
Pauls39 | -- 08-07-2013 @ 6:37 AM |
Seems as though the 42-48 driveshaft is an inch or so longer.
houseof34s | -- 08-07-2013 @ 8:10 AM |
Thank You sir, for your responce regarding the 40 Diff swap. houseof34s
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6380 |
