ldh2176 | -- 07-28-2013 @ 8:55 AM |
Again in need for a little help. In need of '41 front suspension bushing removal tool for shackles and stabilizer bar. Anyone know where I might be able to buy these tools?
ford38v8 | -- 07-28-2013 @ 9:15 AM |
The shackle pin can be loosened to the point that it will fall ou by heating it red hot. The bushing itself is best cut with a hacksaw. NOS shackles can be had, but much easier to deal with are the teflon? bushed shackles from Speedway. Alan
supereal | -- 07-28-2013 @ 10:29 AM |
A handy tool to remove bushings is a "muffler cutter". It is a chisel with a scooped end that peels back and curls the bushing. It is available anywhere professional tools are sold.
ldh2176 | -- 07-28-2013 @ 1:05 PM |
Good advice as always. Thanks alot. This message was edited by ldh2176 on 7-28-13 @ 1:05 PM
Gene | -- 08-22-2013 @ 3:02 AM |
You can also just run a tap into a bushing, and... when the taps bottoms out the bushing will screw itself out, as like in a pilot bushing in the crankshaft. Or tap the tap with a hammer to drive out a bushing, like in a leaf spring.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6351 |
