Swingshift | -- 07-09-2013 @ 10:26 PM |
Unable to keep 2 hubcaps from popping off. Wheels seem fine although the clips may be a bit off. Any ideas with adhesives or possible drilling? Afraid of trying anymore without a solution.....
Old Henry | -- 07-10-2013 @ 7:24 AM |
Don't know how the 36 caps are held on but I use Velcro strips on my 47 caps to keep them from rattling. May work on yours. If I can find my camera I'll post a picture. Old Henry (The older I get, the better old looks.)
Swingshift | -- 07-10-2013 @ 8:59 AM |
Thanks Henry, I'll give it try !
kubes40 | -- 07-10-2013 @ 9:30 AM |
If all of the clips are intact I'd suggest taking a drift with at minimum a 1/4" round tip and placing it near the bend in the clip, give it a blow with a 1# hammer. You'd be amazed at how much this little "trick" often helps.
CaliforniaBorn36 | -- 07-11-2013 @ 2:59 PM |
Had the same problem with my 36. Answer: A few dabs of rtv around the edge. Apply, wipe of excess that squishes out, let dry aprox 24 hours...and done. I lost several hiubcaps, but none in the 500 miles I have driven since applying the RTV. I heard this from someone else who had successfully used this solution.
dicker | -- 08-24-2013 @ 2:13 PM |
While we are on the subject of hub caps, I have never been able to find what is the correct hubcap for the 36 Ford. I have several, some of which the script goes in and several where the script goes out and several with a base cap and with a swedged or pressed on outer cap which I have seen painted with the body color. I am confused. When I refer to the 35/36 Bible, and other references, I find nothing to help my confusion. Dicker Dick Kurtz
nelsb01 | -- 08-25-2013 @ 8:03 AM |
1936 are 'innies' and 1937 are 'outies'. the stamping on the stainless in 1936 is stamped in, and the stamping on the 1937 is raised out (or stamped out).
dicker | -- 08-26-2013 @ 9:36 AM |
Thanks for the hubcap info. I will separate and make sure that my car is a "go-innie". Dicker Dick Kurtz
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6291 |
