41woodie | -- 06-23-2013 @ 3:03 PM |
Advised about 3 years ago to put an 8 volt battery in our 41 ford by an old mechanic to help starting. Car is used only around neighborhood and local shows. I know knowledgeable guys on forum don't recommend these batteries. I bought a 6 volt optima and car will not start. I have adapter on distributor that uses hotter coil. After cranking off and on with new battery, the negative cable was very hot. The oil pan has the grounding bracket installed and ground cable from positive to firewall looks ok. Thanks in advance for help.
oldford2 | -- 06-23-2013 @ 5:58 PM |
Not a good idea. Just a patch on problems you can fix. Do a "search" on Fordbarn.com "8 volts" for lots of good advice. John
40cpe | -- 06-23-2013 @ 6:05 PM |
The hot cable is telling you that there is too much resistance in the cable. It could be from corroded connections or terminals, resistance between the cable and the end connectors, or the cable wire is just too small, as in a cable designed for 12 volts. The cable should be designed for 6 volts, usually size "0" or "1-0" wire. You didn't mention a cable from the block to the firewall to complete the ground circuit. Installing the positive cable directly to the block reduces the chance of resistance in connections to the firewall and then to the block. All the cables need to be of proper size and all the connections clean to provide maximum cranking power.
ford38v8 | -- 06-23-2013 @ 6:21 PM |
Woodie, I have a couple of answers fore you, and a request, which comes first: Please follow up on the answers you get here. We like to help, but we also like to hear if our advice did you any good. OK, first, I'm glad you disregarded the old mechanic's advice to get an 8 volt battery. An 8 volt battery is only a band aid, not a fix. The Optima you did get is one of the best things you could have done, so good on ya! The "grounding bracket" on the oil pan can do that, but it's main function is to support the generator against twisting away from engaging the flywheel under load. Another must have item for that reason. The cable running hot sounds like the real culprit here. You may have a 12 volt cable, not big enough to carry the load. You need 00 AWG for a 6 volt system. !2 Volt cables are smaller gauge, I think maybe 2 AWG ? Not sure. Another reason cables get hot is the terminals themselves. A dirty or loose terminal will produce heat from the resistance, just as a small cable will have resistance. Clean the terminals to bright metal, and use dialectric grease in all connections during assembly to prevent oxidation, the devil of electrical resistance. Alan
fla48 | -- 06-23-2013 @ 6:26 PM |
Also make sure the attach points for the ground cables on the firewall and engine block are clean, not painted. I agree with 40cpe about the connections.
TomO | -- 06-24-2013 @ 8:30 AM |
The hot ground cable should be checked out, but I don't believe that it is your problem. Did the starter spin at a normal speed or did it struggle to turn the engine over? If the starter struggled to turn the engine over, check the voltage drop from the NEG terminal of the battery to the connection on the starter by connecting your voltmeter COM lead to the NEG battery terminal and the POS lead of the meter to the starter motor terminal. Crank the engine and read the voltage. It should not be more than .5Volts. If it is more than that, move the POS lead back one connection at a time and read the voltage the same way. Each connection should not read more than .1volt drop (that is : battery cable at battery to solenoid .1V, battery cable to starter cable on solenoid, .3V, etc.) The grounded side of the starter circuit should be checked out the same way by connecting the POS lead of the meter to the POS terminal of the battery and the NEG or COM lead of the meter to the starter case. The reading should be .1Volt or less. Higher readings could be caused by bad ground cable, bad connection at the fire wall on both the battery cable and the engine cable or a starter that has the oil pan mating surface painted. These tests will show you which components are not up to the job. You are using a modern coil, but did you check the spark? It should be at least 1/4" when cranking the engine. Most of the modern coils sold have an internal resistor and the resistor under the dash should be bypassed by hooking bot wires on the same terminal. Did you check for gas in the carburetor? Try spraying some starting fluid in the carburetor. Tom
supereal | -- 06-24-2013 @ 8:52 AM |
As noted above, the bracket that secures the end of the starter (not generator, Alan) is to lessen torsion of the starter. Follow TomO's good advice regarding measuring the voltage drop of each component of the system. If all checks out, it is likely that the starter motor, itself, is the problem. Worn bushings permit the armature to drag on the pole shoes. In that event, repair or replacement is the cure, not an 8 volt battery.
Brendan | -- 06-24-2013 @ 4:26 PM |
Brake Ohm's Law go to jail... lol. the first thing is figure out why the cable is getting hot. I bet it is too small. and connections are dirty. with Ohm's Law, the lower the voltage the higher the current, and higher voltage lower current. its kind of like filling a swimming pool with a 1/2 in hose, or using a 2in hose. I hope thus helps Brendan Can't spell my way out of a paper bag!
TomO | -- 06-25-2013 @ 7:42 AM |
The cable could be hot because the circuit is drawing too much current or because there was not enough time between the cranking of the engine to allow the cable to cool off. The above tests will show if the cable has excessive resistance or the problem is in the starter. The starter motor should draw between 150-200 amps, with most of them at the lower reading.The stock 6 volt cable is 2 AWG for 37-48 Fords. The earlier cars with the battery under the floor should probably use 1 AWG due to the longer length of the cables. The 2 AWG cable will drop about .1 volt for each 2 ft of cable at 6 volts when 200 amps of starter current runs through it. It will stay cool to the touch if the 15 second - 1 minute rule is observed. That is 15 second of cranking and 1 minute of cool off time. This rule was set to preserve the starter motor and prevent it from overheating. If this rule is ignored, the starter and the cable will get warm to the touch. Tom
41woodie | -- 06-27-2013 @ 1:44 PM |
thanks top everyone who responded to my questions about 8 volt battery. I took my dremel and sanded down all the grounds and got a heavy duty cable from a tractor supply store. car turns over and starts great.i'm a novice at this so probably have more questions in the future. thanks again for helping me out.
41woodie | -- 06-27-2013 @ 1:45 PM |
fla48 | -- 06-27-2013 @ 4:09 PM |
Glad you got the problem successfully resolved. Do not hesitate to ask questions here. There is a world of information available for the asking. And it is free.
supereal | -- 06-28-2013 @ 2:40 PM |
At our shop, we have removed several aluminum battery cables that have come in with starter problems. Since copper got very expensive, there has been an attempt to substitute aluminum. This started with jumper cables (no pun). Aluminum forms an insulating oxide at the exposed ends. This high resistance can make the cables hot enough to melt the covering. If you buy cables, particularly for 6 volts, they should feel very heavy. Otherwise, look elsewhere.
Brendan | -- 06-28-2013 @ 7:52 PM |
number 2 awg is only good for about 90 amps that is ohms law that is why you cant brake it. you need 2ott for 200 amps. amps is amps in ac or dc it dose not matter Can't spell my way out of a paper bag!
TomO | -- 06-30-2013 @ 6:36 AM |
Brendan, I don't know where you got your information, but the original cables were 2AWG and this site confirms that the voltage drop per cable will be about .1 volts for an 18" length cable with 200 amps and 6 volts. Tom
Brendan | -- 06-30-2013 @ 1:34 PM |
look in the National Electrical Code! table 310.16 #2 copper is good for 95 amps and 2/0 is good for 145 amps. and 250 mcm awg is good for 215 amps. Can't spell my way out of a paper bag!
51f1 | -- 07-01-2013 @ 6:56 AM |
I think that the 95 amp limit in the NEC has more to do with insulation and the type of use than than the current carrying capacity of the wire. There are #2 single conductor cables that are rated for 240 or more amps. Number 2 welding cable is rated for 205 amps max. In careful engineering, the voltage drop, insulation temperature limit, thickness, thermal conductivity, and air convection and temperature are taken into account. Only wiring systems conforming to the National Electrical Code must use their guidelines. I made up a cable for my truck using 2/0 cable. The max rating of 2/0 is 380 amps. It may be overkill, but it sure works well! Richard This message was edited by 51f1 on 7-1-13 @ 1:34 PM
TomO | -- 07-01-2013 @ 7:08 AM |
The NEC code is for power transmission, not short power leads. The AWG table gives the current carrying capacity of short power leads. Here is the link that I forgot in my previous post> http://www.powerstream.com/Wire_Size.htm Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6212 |
