Bob56 | -- 06-22-2013 @ 7:36 AM |
What is the best way to remove the sensor from the water pump (1936). Finally got the nut to unscrew but the sender doesn't want to com out. Sprayed with WD-40 will not move.
keith oh | -- 06-22-2013 @ 2:18 PM |
You will probably have to remove the water pump and gently tap the sensor from the back also. A mixture of 50-50 ATF/Acetone penatrates best of all.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6207 |
