Ralph E | -- 06-15-2013 @ 8:01 AM |
1933 Fordor. Excessive play in steering, most of it is in the steering gear box. Seems like too much to adjust out. I want to remove the steering box and replace gears/bushings or rebuild as condition indicates. The box location is very tight between engine and frame with a long steering sector shaft. Even taking off left exhaust manifold, it looks like it will be a tight fit to remove the steer box. Appreciate any tips on how to remove the steering gear box. Thanks.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6177 |
