lkeough | -- 06-09-2013 @ 11:10 AM |
I am in the process of rebuilding my '36 passenger headlight buckets. Does any supplier make a replacement spring clip for the fender mounting bolt pivot? Also, are there any special precautions for removal/installation of the clip? My clips are intact, but I would like to remove them to thoroughly clean the pivot and mounting bolt. Thanks for any "light" you can shed.
trjford8 | -- 06-09-2013 @ 8:11 PM |
Nobody makes that clip to my knowledge. I believe it is riveted on, so you could drill out the rivets and re-rivet back in place later.
40 Coupe | -- 06-10-2013 @ 3:43 AM |
Contact Fred at Southside obsolete for NOS. I believe they are on his web site.
nelsb01 | -- 06-10-2013 @ 6:42 AM |
http://www.southsideobsolete.com/Southside_Obsolete/1935-1936.html Check this page out. Fred will be at the Grand in Tahoe if you want to talk to him.
lkeough | -- 06-10-2013 @ 2:06 PM |
Thank you for the lead to Fred at Southside Obsolete. He does have them on his website, and I left him a phone message. My clips are not riveted. They are secured by a bent tang at each end. There is a notch at one end of the clips, and it appears that they should slide away from the notch and lift out. Has anyone done this? Thanks. Larry Keough.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6149 |
