sturgis 39 | -- 06-09-2013 @ 1:15 AM |
I have a 39 standard and there is about a 3" hole in the center of the firewall.I think it is for the exhaust type heater. Do they make a plug for this hole? The hole is above the oil breather. IF IT CAN NOT BE FIXED WITH BLASTING WIRE, DUCT TAPE OR JB WELD - IT CAN NOT BE FIXED This message was edited by sturgis 39 on 6-9-13 @ 1:19 AM
40 Coupe | -- 06-09-2013 @ 4:27 AM |
Yes the hole is for the Hot air heater, no the aftermarket suppliers do not have a plug, you will have to make one and tack it in a couple of places.
trjford8 | -- 06-09-2013 @ 6:44 AM |
You might find something at a plumbing supply store that would work temporarily.
sturgis 39 | -- 06-09-2013 @ 7:39 AM |
Did Ford make a plug originally for the hole? IF IT CAN NOT BE FIXED WITH BLASTING WIRE, DUCT TAPE OR JB WELD - IT CAN NOT BE FIXED This message was edited by sturgis 39 on 6-9-13 @ 7:40 AM
Stroker | -- 06-09-2013 @ 9:30 AM |
Sturgis 39: It was just a "knock-out" portion of the firewall, so that the dealer wouldn't have to use a big hole saw. Similar to the knock-outs on electrical junction boxes, except flush with the surrounding surface.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6146 |
