smiley | -- 05-29-2013 @ 7:03 PM |
Greetings, I have a 49 conv. and the fuel pump has retired. C&G lists two types one a single action and a double action. What is the difference? I'm not sure which one I need,I think just a single action but would appreciate some guidance. Thanks
deuce_roadster | -- 05-29-2013 @ 7:30 PM |
The double action ones have another part on the bottom that creates vacuum so the wipers work better. If the one on your car has a vacuum hose coming from under the fuel part it is the double action version. If it looks like a regular fuel pump, only has a fuel line going in and a fuel line to the carb it is the single action one. The doubles are about twice the size of the singles also.
smiley | -- 05-31-2013 @ 2:25 AM |
Thanks Deuce, I ordered the single action. Can't wait to get back to driving the 49
flathead4rd | -- 05-31-2013 @ 2:24 PM |
You might want to conside changing the push rod also since you have it apart. It doesn't take a lot of wear to make a difference in pump output.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6100 |
