shogun1940 | -- 05-27-2013 @ 7:06 PM |
can any post a picture of the upper bolt mount for a 48 rear tube shock so I know what iam looking for or does anyone have two to sell
supereal | -- 05-29-2013 @ 11:18 AM |
C&G (800/266-0470) has the tube shock kits. For '48, the rear kit is 11A-18125-KIT, $212.95 My '47 has tube shocks, front and back. The my rears use upper mounts that clamp on the cross member.
Old Henry | -- 05-29-2013 @ 4:10 PM |
Here is the green bible diagram showing the post for upper shock mount. Old Henry (The older I get, the better old looks.)
shogun1940 | -- 05-29-2013 @ 6:39 PM |
thank you old henry, i have the bottom brackets , now i can look for those top bolts thanks again
40cpe | -- 05-30-2013 @ 3:56 PM |
You will notice that the top mounts in the picture Old Henry sent mount through the rear crossmember. I don't know what year model you are going to install them on, but I don't think they are a direct fit for earlier model cross members. I put a set on my '38 and had to lengthen the part the goes through the crossmember by about 3/4". Various suppliers have the type that just bolts the the front flange of he crossmember.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6095 |
