msmaron | -- 05-09-2013 @ 9:40 AM |
I have a 31 model A and going to install the B distributor with the centrifugal advance. I also have a B timing cover to get the D-Dent to the right spot to achieve BTDC.... 1. Do i just set the timing like any other model A, but turning the cam JUST before the points open or is there a secret to getting it just right, 2. How do i adjust the little screw on the side....to dial it in perfect..any help would be appreciated. Thank you Mark
TomO | -- 05-10-2013 @ 9:08 AM |
Here is a link to timing a Pertronix conversion of a Model B distributor in a Model A. A point distributor should time very similar. http://www.fordgarage.com/pages/ignitorB.htm While you are on the site, check out the video of how to tell when your Model A is timed right. Tom
37RAGTOPMAN | -- 05-13-2013 @ 4:45 PM |
HI just to let you know, the A cam is Different from the B cam, it might or might not make a difference hope this helps. 37RAGTOPMAN
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=6014 |
