39topless | -- 04-26-2013 @ 7:36 PM |
My '39 is not level and it's enough to notice. There is a height difference of 1" from one side to the other in the rear. Is there someway to "adjust" the height? Thank you, Phil
ford38v8 | -- 04-26-2013 @ 11:47 PM |
It could be as simple as a rebuild for your shocks, but likely will entail disasembly of your springs to grind off the wear ridges and apply new fifth wheel grease. It's a dirty job, but someone has to do it. Alan
39topless | -- 04-27-2013 @ 9:12 AM |
Please, say it ain't so! Thanks for the reply.
alanwoodieman | -- 04-27-2013 @ 12:12 PM |
check your spring shackles/pins for wear, also make sure your spring is centered and held there with the aquare head bolt that holds the spring pack together. Just fixed a 40 coupe that the tie bolt was broken and the springs had slipped to one side
woodiewagon46 | -- 04-27-2013 @ 1:33 PM |
Also check the "U" bolts that attach the spring to the crossmember. A friends car somehow broke one side and his car was leaning to one side.
supereal | -- 04-28-2013 @ 6:06 PM |
In addition to the good advice above, consider swapping the spring end for end when you put it back. Over decades, springs take a "set". Turning them can often restore the height.
39topless | -- 04-29-2013 @ 9:01 AM |
Great suggestions. I will work on this and reply with the solution. Thanks guys.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5974 |
