nstanley | -- 04-25-2013 @ 4:06 PM |
All, I'm putting together a 59A I've just gone through, and I have reused the original head studs, replacing a few damaged ones with other spare used ones so that all are in excellent shape with good threads. Stock 59AB iron heads. I cannot get most of the studs of 52 ft-lbs without the studs stretching/yielding. I tried a few in a cracked block, and 60 ft-lbs will break them. I am using new plated nuts from Mac's and 10W-30 on the threads and nut faces. Has anyone else seen this? I have one head on and all the studs took a solid 50-52 ft-lbs. I have yet to do the other side. SHould I pull it back apart and replace all the studs? WHo do you recommend getting studs from? Thanks, Nick.
supereal | -- 04-25-2013 @ 4:25 PM |
We always replace all studs or head bolts when rebuilding. The constant heating and cooling anneals old studs and makes them weak. Our choice is ARP studs. A bit more expensive, but cannot be beat. Oiling studs and/or nuts skews the torque readings.
fla48 | -- 04-25-2013 @ 5:17 PM |
Also, do not use a lubricant on studs nuts or bolts when torquing as this caused an over torque condition.
TomO | -- 04-27-2013 @ 8:23 AM |
Roy Nacewicz sell quality stud sets for your engine. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5969 |
