nelsonford | -- 04-22-2013 @ 3:04 PM |
Where is the best place to buy a new mechanical v8 ford fuel pump that is Ameican made with proven quality?
c-gor | -- 04-22-2013 @ 6:08 PM |
I have great luck with the Airtex pumps. Have purchased mine through Car Quest. Also go to Airtex web site for info. Web address http://www.fuelpumpu.com/vehicle-search.aspx#
nelsonford | -- 04-23-2013 @ 5:17 AM |
Thanks c-gor. I will keep that in mind but I think I want to try to stick with the mechanical pump. Maybe I will have to go electric in the future with the new e-10 gas problems with the old cars.
37 Coupe | -- 04-23-2013 @ 6:30 AM |
I bought a new not rebuilt mechanical fuel pump from Napa just a couple years ago and it is made in the USA. I think I still have the box if you need a number but if you go to Napa and tell them you need a fuel pump this is the one that will come up. I started my engine up in 2007 with a supposedly quality rebuilt pump from an old but NOS one in the box.Even though I was promised that the diaphragm would withstand ethanol it failed within 6 months.Was rebuilt another one by another"fuel pump and carb guru"same results. I figured from what I read on forums that Napa or anything new would be Chinaman made and really junk why I never really bought a new one. Finally had to but figured it would be just another temporary one but it had been dependable now for 4 years,also cheaper than rebuilds. Airtex also makes mechanical ones not neccesarily electric as you assumed from previous post. I think one from Napa may have been made for them by Airtex or mayby had Federal Mogul on the box somewhere,also Airtex may be Carter?
supereal | -- 04-23-2013 @ 6:33 AM |
Airtex also makes mechanical pumps. Finding any made here is tough because most are foreign made. Airtex makes them in Mexico, mostly.
TomO | -- 04-23-2013 @ 6:57 AM |
Speedway Motors sells an Offenhouser pump that is made in the USA. Rockauto.com sells the Airtex for $28.79. I prefer the Offenhauser pump as it keeps a higher residual vacuum. Tom
nelsonford | -- 04-23-2013 @ 10:19 AM |
Thanks Guys, I think I'll go with the offy pump from Speedway. I need some other parts from them as well.
ken ct. | -- 04-29-2013 @ 5:41 PM |
46 pump is an all steel bowl one // 47-48 are glass bowl ones.I have both availible in genuine "AC" brand with usa made parts and super corn gas proof diaphrams and valves.Garenteed at least 1 yr. 46 pumps are $70 outrite and glass bowl ones are $80 outrite and contain a pleated paper filter installed in the bowl. Ive sold hundreds of flat head pumps and have good luck with them. ken ct. 1-203-260-5945 cell
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5958 |
