kenburke | -- 01-12-2010 @ 6:10 PM |
I have a 40 with a 59 a/b. I want to install a correct 40 intake. Its not aluminum. So the correct # and length for the push rod would be...?? And how many variations are there? Thanks
supereal | -- 01-13-2010 @ 6:18 AM |
The correct rod for a '40 with iron intake is is 6.375". The rod length for the 59A 32-48 is 8.872 for cast iron. The difference is due to the height of the pump stand. The green book shows half a dozen lengths, depending upon year and type of manifold and engine.
kenburke | -- 01-15-2010 @ 11:38 AM |
Hi Supereal, Thanks, At least I am now heading in the right direction. I'll check on my pump stand specs and everything else that makes a difference.
37 Coupe | -- 01-15-2010 @ 4:49 PM |
I believe the 6.375 in. mentioned is for the 60 h.p.The aluminum manifold would use a 7.872 length and cast iron manifold makes it an inch longer at 8.872 # is 48 9400-A
supereal | -- 01-16-2010 @ 10:38 AM |
You are correct about the 6.375 rod. Doggone trifocals, anyway. The other two lengths are correct if the fuel pump stand and manifold is correct for the engine, 32-48.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=594 |
