pcasner | -- 04-01-2013 @ 6:32 PM |
The recommended method for checking valve clearance is for the lifter to be on the heel of the cam. How can I be sure the lifter is on the heel of the cam since you can't see the cams? Can I assume that when the lifter is at it's lowest vertical travel that it corresponds to the heel of the cam? Appreciate your help. Thanks Paul
TomO | -- 04-02-2013 @ 7:35 AM |
There is a chart in the 39-48 Service Manual reprint that works pretty well, but I use this method. http://www.btc-bci.com/~billben/lash.htm Tom
pcasner | -- 04-03-2013 @ 7:22 AM |
Thanks Tom, I will try that.
supereal | -- 04-04-2013 @ 11:21 AM |
Here is a chart that will simplify valve setting, and eliminate turning the crankshaft a lot: X= Exhaust N= Intake valves. When these valves are open: Adjust these valves: 4X+1N 3X 8N 6N 7X 3N 2X 3X+4N 1X 7N 5X 2N 4X 1N 1X+7N 8X 5N 6X 4N
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5890 |
