rblong | -- 03-25-2013 @ 1:21 PM |
Can the small air cleaner be disassembled for cleaning and installing new mesh? All the parts seem to be pressed fit.
flatheadfan | -- 03-26-2013 @ 9:26 AM |
This question comes up frequently. Unfortunately, there is no easy way to install a new copper mesh without cutting some of the supports and reattaching them later (braze or weld). Starting in '37 - no problem. If you are looking for a "Plan B" consider an oil bath filter. These were an available option in '36 and no mesh is really involved. Plus, it does a better filtering job for the engine. Tom
rblong | -- 03-26-2013 @ 10:06 AM |
Tom, Thank you for your reply. I think I will soak it in "Oil Eater" liquid and clean the mesh. If the mesh is destroyed, then I will cut those supports, replace the mesh, reattach the supports and then paint. Ron
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5865 |
