1935ford | -- 03-23-2013 @ 2:40 PM |
Anyone have dynamic coefficient of friction values for woven and molded brake linings against steel? Thanks! Roger J.
ford38v8 | -- 03-23-2013 @ 3:11 PM |
Roger, the dynamic foot pedal pressure required to skid a Ford to a stop with woven shoes is equal to the pressure needed to break 3 eggsh*lls per each 15 MPH. Under the same circumstances, dynamically speaking, molded shoes will require 5.25 egsh*ll pressures to produce the same skidmarks. Upon close examination of both sets of skidmarks, experts agree 2 to 1 that they cannot agree as to which set was which. All of which proves nothing, and the only true experts on the subject, really, are the eggsh*lls who were actually on the scene to witness the test first hand. Alan
Stroker | -- 03-23-2013 @ 9:50 PM |
Alan: Methinks you are in "jest".
ford38v8 | -- 03-23-2013 @ 11:23 PM |
Dan, you are correct, and on second thought, let's hope the coefficient of my jest is smiles all 'round, as I'm afraid a punch in the nose would be most dynamic. Alan
TomO | -- 03-24-2013 @ 11:11 AM |
Roger, there is no single answer for your question. Different suppliers use different compositions to create what the supplier thinks is a good compromise between stopping ability and wear. With mechanical brakes, look for bias toward stopping. Longevity should be a minor consideration in a car that is not used as a daily driver. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5859 |
