Steves46 | -- 01-10-2010 @ 2:41 PM |
Even here in Florida, my 46 is running way too cool without them. Since I understand the NAPA thermostats seem to be the best suited, does anyone have the P/N? Thanks.
37RAGTOPMAN | -- 01-10-2010 @ 4:05 PM |
steve46 I put a NAPA thermostat in a 4 cylinder Jeep F HEAD,and ALL it did was stick and almost overheat the engine,. it seemed to also most overheat then pop open, but one day the coolant blew all over,when I was plowing snow, so out came that piece of Junk. try finding some NOS STOCK, or give THE V8 SHOP a call or JOBLOT in NY,or LITTLE DEARBORN, THEY be a better way to go,they are always on e-bay just my 2 cents,37RAGTOPMAN
Steves46 | -- 01-10-2010 @ 4:10 PM |
Thank you; I will give them a call and keep an eye on E-Bay.
Stroker | -- 01-10-2010 @ 4:34 PM |
If all else fails, an old trick we used in the 50's in "Sunny So.Cal." was to install a fender washer the same diameter as the ID on the stat, with a 3/8" hole. The dual pumps on flatmotors will often pump so fast that the water doesn't have time to lose heat going through the radiator. The fender washer slows the coolant flow down to allow this to take place. Another (although "draconian") trick was to drill a 1/4" hole in each water pump impeller blade for the same reason.
ford38v8 | -- 01-10-2010 @ 5:34 PM |
Stroker, now you've opened up a real can of worms! I'm afraid, though, that the vast majority of guys these days will team up against that old opinion. The fender washer doesn't do any harm, but neither does it do any good, as the water will have shed as much heat as it gained in the same amount of time in the block. The holes in the water pumps were devised as a horsepower conservation measure in the oval track days. The function of the thermostat is to regulate the temperature. In most cases, it will open and remain open, but in extreme temperatures, a two or three square foot section of cardboard in front of the radiator will help the situation. Alan Alan
Steves46 | -- 01-10-2010 @ 6:24 PM |
Didn't mean to open a can of worms for I know this has been a "popular" topic over the years. Just finished rigging a 18 in wide x 10 in high piece of cardboard and placed it against the lower part of the radiator. Fired her up and within less than 10 minutes my mechanical gauges were reading 160. Much improvement! Thanks.
40fordor | -- 01-10-2010 @ 7:32 PM |
37RAGTOPMAN, I was on another forum and read that thermostats placed in old F head Jeeps needed a small weep hole drilled in them (if not already there) to allow just a little flow through it to prevent the problem that you described. It has been since the 50's that I was around those Jeeps but I had great fun with them. Check out a Jeep forum to verify what I read. Don
51f1 | -- 01-11-2010 @ 12:33 AM |
Why are NAPA thermostats best suited? All brands are probably made in China and all brands are subject to failure. Go to any reputable parts dealer and buy your thermostats (NAPA will do just fine). Why do you leave out the thermostat? The thermostat serves the purpose of regulating your coolant temperature and accelerating warm-up. Leaving it out makes no sense. The guys who designed your engine knew what they were doing. If your engine doesn't cool with a thermostat in it, find out why and fix the problem. Richard
Stroker | -- 01-11-2010 @ 6:06 AM |
All: Sorry about the worms. I believe Alan's response to my fender washer recollection is probably spot-on. After further thought, I think the fender washer trick was designed to mitigate the problems we created by throwing the thermostats away, wrongly assuming that they were the cause of heating problems. I'll plead CRS, and go apply for my "Geezer Plate" at the Auto Dept.
37RAGTOPMAN | -- 01-11-2010 @ 8:41 AM |
40fordor When , I had that problem, of overheating in a middle of a snow storm, I removed the NAPA thermostat and looked at it, boy did in look familar, I went into my shop and had a few new 49-53 FORD FLATHEAD thermostats, and matched it up, it was a exact fit,same thermostat fit many many different make of cars,for years, not like today,,,, it was a 155 degree and it works perfect, a little less heat ,BUT ,I can live with it, I stay away from a lot of NAPA parts, most of them are made in CHINA, ever use a reman alternator, or starter,from NAPA, these are terrible, and not a warranty I can go to AUTOZONE to buy CHINA,at a cheaper price, its funny the CHINA parts are getting also expensive to buy also, they used to be cheaper, I think NAPA should have a better quality control, they should have put a small hole in the thermostat in the first place,,if that what was wrong with it, I threw it away, what a piece of c----,! why should the customer have to repair a new part to make it work, thanks,old JEEPS are fun, mine is a 64 CJ5, were is the old JEEP WEB SITE, can you repley to this to let me know, thanks 37RAGTOPMAN
40fordor | -- 01-12-2010 @ 9:17 AM |
37RAGTOPMAN I cannot remember where I read about the Jeep flat head therostats. It probably was in some magazine that caught my attention because my father had a 1951 Jeep when I was in high school (1950-1954). As I remember the article stated that some thermostats had the hole and some did not, but overheating was a result in most cases without it. Don
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=583 |
