sunflower | -- 03-09-2013 @ 1:08 PM |
On my 35Ford when the engine is idleing I get a pop ping out the drivers side exhaust pipe once in a while, what would cause this? Thanks
supereal | -- 03-09-2013 @ 1:48 PM |
If it just occasional, I'd suspect a sticky valve. If it happens more than that, it may be a vacuum leak somewhere in the carb area, such as a cracked hose or leaky gasket. For the valve, you can try some Marvel Mystery Oil in the gas, or a bit down the carb. If it persists, I'd run a vacuum test. I'm attaching a chart.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5808 |
