zeker8 | -- 02-26-2013 @ 10:45 AM |
Anyone know if 40 passenger headlight buckets would fit a 37 passenger fender ? I like the sealed beam. Zeke
trjford8 | -- 02-26-2013 @ 6:07 PM |
Zeke, they will not fit without some modification to the fender. If you want sealed beams in your 37 check the swap meets or e-Bay. They made after market sealed beam kits specifically for 37's and I see them frequently at swap meets. There's currently a set on e-Bay now. Check item # 251235052987. Current bid is $1. I suspect you can buy the kit for less than $25. If you look at the headlamp bezels they are much different than those for a '40. This message was edited by trjford8 on 2-26-13 @ 6:11 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5775 |
