woodiewagon46 | -- 02-07-2013 @ 9:40 AM |
Can anyone recommend the best date code etching kit, or "bug" as I have heard them referred to, for some of the glass on my 1946 Ford.
nelsb01 | -- 02-07-2013 @ 11:33 AM |
Only one that I know on the market is Roy Nacewicz check it out at www.fordscript.com
kubes40 | -- 02-07-2013 @ 12:09 PM |
I have used a number of Roy's kits. They are the best... period. Easy to use even if it's your first time. Roy's number: 734-654-9450
Henryat1140 | -- 02-07-2013 @ 7:16 PM |
He'll send you enough stencils and materials so you have extra supplies to practice with. Try the etching on a piece of scr*p glass first. It's pretty easy and produces good results.
Henryat1140 | -- 02-10-2013 @ 6:27 PM |
Just thought of something else. . . . The date code on the bug will usually be a couple of months PRIOR to the car build date, so factor that in when you order the kit. Henry
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5701 |
