joe shell | -- 02-04-2013 @ 9:32 AM |
Lost key to repro locking gas cap for my 36 Ford. Any ideas on removing the cap without damage to the tank filler pipe? Thanks,
37RAGTOPMAN | -- 02-04-2013 @ 4:42 PM |
if I had that problem. I would drill out the tumbler carefully., USING A VACUUNM.to catch the filing you could also call a locksmith, they should be able to pick the lock and make you a key, drilling out the lock and buying a new gas cap will be cheaper, my 3 cents 37RAGTOPMAN
trjford8 | -- 02-04-2013 @ 7:58 PM |
Check with the manufacturer of the repo cap. Perhaps they have a suggestion on how to solve the problem. Most of those caps come with two keys, what happened to the second key?
TomO | -- 02-05-2013 @ 10:27 AM |
Those locks are very easy to pick. You could also ask around to see if you can try someone elses key in your lock. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5689 |
