zuktom | -- 02-04-2013 @ 7:13 AM |
Where can I purchase a 36 radiator new or like new thanks
WKnighter | -- 02-04-2013 @ 10:40 AM |
Available new radiators do not have clearance under top tank for the fanblade. You would have to install an electric fan or have your old radiator recored.
JM | -- 02-04-2013 @ 5:41 PM |
You can probably find new NOS if you are lucky. Finding a used one that is really good is also difficult. I think a recore of your old if the tanks are good may be your best bet but make sure you and they take all the necessary measurements and make the recored radiator exactly like the old one. Otherwise, you will have problems with fit of grille and other front end sheetmetal. JM
transbytip | -- 02-04-2013 @ 9:34 PM |
Have a very good original 36 rad.From my 36 conv.sedan Found a n.o.s. Have it out twice for leaks.Should have left original in car.E-mail tipper52501@yahoo.com,L.L.(641)682-6091 Cliff Tipton. with reguards Cliff. Tipton
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5686 |
