Steves46 | -- 02-04-2013 @ 4:34 AM |
As a beginning step to replacing the worn transmission mount on my 46 Coupe, I will be removing the floor board in order to gain access to the 2 bolts that connect to the "rabbit ears" of the transmission. However after examining the 2 bolts that hold the mount to the frame cross member, I ran into a snag-it is not wide enough to fit a socket or wrench over the nut on the bottom. For those who have done this I would greatly appreciate any suggestions. Steve
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5684 |
