Esteban34 | -- 01-24-2013 @ 10:32 PM |
Did original 1934 Fords have an upper door seal? adonde vas, estas alli Esteban
Old Henry | -- 01-25-2013 @ 8:16 AM |
C&G says yes and sells it here: https://secure435.hostgator.com/~dlvry40/ufolder/ShowProducts.php?c=1&s=45&g=376&t=2168&tn= Mac's sells two sizes - a short one for the tudor: http://macsautoparts.com/early-v8-ford-mercury-upper-door-seal-pair-2-32-1-2quot-pieces-ford-tudor-40-7043724-b/camid/F30/cp/JS0R3CHL1142417/ and a long one for the fordor: http://macsautoparts.com/early-v8-ford-mercury-upper-door-seal-kit-2-54quot-pieces-ford-fordor-sedan-40-7043724-c/camid/F30/cp/JS0R3CHL1073084/ Old Henry (The older I get, the better old looks.) This message was edited by Old Henry on 1-25-13 @ 8:20 AM
kubes40 | -- 01-25-2013 @ 8:38 AM |
My extremely authentic '34 coupe has the original (albeit dry)seals.
supereal | -- 01-25-2013 @ 2:53 PM |
The coupe and the 2D use the same seal kit, 40-7043724`AS. The 4D is 40-7043724-BS at C&G. $10 for the short kit, $15 for the 4D long kit. There is also a lower door seal,40-701980, $10. When installing door seals with cement, be sure not to stretch them, or they will likely work loose.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5656 |
