MOXIE | -- 01-04-2010 @ 5:46 PM |
Is there anyone reproducing the complete exhaust system for a 1935 V8 car that will actually fit without reworking. I installed a system in a 1934 car and had to use the torch to bend pipes to make them fit, esp. the cross over pipe.
supereal | -- 01-05-2010 @ 8:05 AM |
Most, if not all, prefab exhaust systems require substantial modifications to fit properly. We have all systems made up at a very good local shop, including some in stainless steel. It is quicker, and usually less expensive, than ordering a system and expecting it to fit out of the box. Look around for a good independent shop, as the franchised places usually seem to think that a "bender" is something you do at a bar!
trjford8 | -- 01-05-2010 @ 8:17 PM |
You might try Waldren Exhaust; www.waldrenexhaust.com. I have found that most prefab exhaust stuff always needs some work. It is not just a bolt-on and go product. I agree with Bob and would go to a good independant muffler shop and have it custom made.
EWATERS | -- 01-10-2010 @ 4:26 PM |
Have you (or anyone) tried "Classic Exhaust" in Geneva, Ohio? I ordered a set for my 1950 Ford with a 6-cylinder engine in June of 2009. I have not yet reached the point of installing it; I hope it works.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=556 |
