rogbell | -- 12-05-2012 @ 7:08 PM |
My '53 has been converted to a 12v system. Do I need to use a voltage reducer for the horns or will they work with a 12v system? They are the original horns. Thanks.
51f1 | -- 12-06-2012 @ 3:53 AM |
Just a thought. I am sure others know more about this than I do as I am strictly a 6-volt guy, but how 'bout wiring the horns in series rather than parallel? Richard
supereal | -- 12-06-2012 @ 12:06 PM |
Horns draw the second most current after the starter, so most voltage reducers can't handle the load. As the ground for the horns is usually not brought as a separate connection, placing them in series can be difficult. You will need to replace the horn relay with a 12 volt type (B6A-13853)in any case. You can obtain 12 volt horns (F4AZ-13833/4), all available at C&G (800/266-0470).
rogbell | -- 12-06-2012 @ 3:04 PM |
Thanks for the advice. I'm usually at C & G once a month.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5499 |
