choupie | -- 12-03-2012 @ 4:22 PM |
There are 3 different length head studs for a 24-bolt 59A engine (8 short ones, 2 medium size ones, and 14 long ones for each head). Which ones go where? And while I'm at it, how much force should I use to seat the bolts in the block? Thanks in advance, Paul
choupie | -- 12-03-2012 @ 6:06 PM |
Nevermind, I figured it out (it's easy when you look at the head instead of the block).
supereal | -- 12-03-2012 @ 9:27 PM |
After applying sealer, turn the studs down into the block until you reach the end of the threads. If you want to clean the threads in the block, obtain a thread chasing tap, not a threading tap, or you will damage the threads in the old fragile cast iron.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5491 |
