41SuperDeluxe | -- 11-27-2012 @ 5:57 PM |
Can anyone tell me the difference in size for a 1939 vs a 1941 Ford split bench seat? ***And if anyone knows - if a 39 bench is fit in a 41 - is it too small in side to side width? If I use the 39 bench - it will be upholstered with custom high grade vinyl per the style my Grandpa did after the war,My only concern is that I do want the bench seat to look like it fits the cars interior ( and not look too small ) Thanks, John
41-42fordadvisor | -- 11-28-2012 @ 7:02 AM |
I don't know the width of the 1939 Ford seat but the 1941 Ford seat is 55 inches wide. You have to remember that the 1941 Ford is a longer and wider car than the 1939-40 Ford car. This helped to increase the interior size of the 1941 Ford. NO the 1939 Ford seat will not fit in a 1941 Ford.
TomO | -- 11-28-2012 @ 8:06 AM |
The 39 seats are at least 4 inches narrower than the 41 and the mounting brackets are completely different. I agree that it would not look correct in a 41 Tudor. I don't have the seat width, but the seating area on a 39 is 50" and a 41 is 55". This is measured across the body at the arm rest height. Tom
41SuperDeluxe | -- 11-28-2012 @ 2:03 PM |
Thank you - I will source a 41 split bench seat - Best, John
trjford8 | -- 11-28-2012 @ 5:06 PM |
The 46-48 is the same seat. You can use the seat from a sedan coupe or a tudor sedan.
Jim | -- 12-05-2012 @ 4:05 PM |
Hi John, I have a very nice front seat that may fill your needs. It still has the tag attached to the spring, and after checking on the forum about a year ago, I learned it was Part o1A (from a 1940 car), the covering was C2 (mohair) and the '70' on the tag means 2 door sedan or business coupe. It is now covered in naugahyde and the springs are in good condition. Have the base as adjustment lever as well. Price is $100 + shipping (located in WI) If you are interested, call me at 941 485 5131 (FL). Jim
TomO | -- 12-06-2012 @ 7:41 AM |
The 40 Ford seat is the same size as the 39, at least 4" narrower than the 41-48 seat. Tom
41SuperDeluxe | -- 12-06-2012 @ 4:38 PM |
Jim - Sounds like your bench is for a 1940 - I need a 41 model split bench - please correct me if I am incorrect in the model year of your bench. Thxs John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5473 |
