chas34 | -- 11-24-2012 @ 8:30 AM |
Can't read any of the numbers on the old bulbs and couldn't find the specifics in the manual ... what bulb is used in this application?
supereal | -- 11-24-2012 @ 10:29 AM |
Those bulbs were used from 1928-1934, and are long obsolete. You can order them as B-13007-D from most vendors. C&G (800/266-0470) shows them as $2.00 each for the six volt type. As I recall, these bulbs used to be sold in two versions, a 32 candlepower and 50 CP. I don't know which they stock.
40 Coupe | -- 11-25-2012 @ 4:52 AM |
The originals were 32/32 CP (low beam / high) as mentioned you may be able to find 50/32 CP which has a brighter low beam (higher current draw). I am not sure but the replacement part number for the originals may be #1000 ??? You may be able to locate an old light bulb chart on the web to confirm this number.
Don Rogers | -- 11-25-2012 @ 2:22 PM |
From 29 to 34 Ford used the same head lamp bulb. Ford called it B-13007-C. It was readily available in the market as #1000. It had dual filaments, each at 32 candle power. See attached image of bulb.
Don Rogers | -- 11-25-2012 @ 2:25 PM |
OOP's Here's a smaller picture
chas34 | -- 11-26-2012 @ 4:55 AM |
Thank you for your input --- I guess no one has an old bulb that has readable numbers, but your info should get me into the right direction ...
Don Rogers | -- 11-26-2012 @ 9:28 AM |
The number on the bulb is "1000"
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5455 |
