trell | -- 11-12-2012 @ 1:00 PM |
What did Ford use behind the 1940 dash to hold the instrument cluster in place? I know there's 4 studs on the back of the dash, but what sort of clamp/bracket was attached?
40guy | -- 11-12-2012 @ 6:14 PM |
It's been a while since I've been under my dash but best I can recall; It's just 4 flat tabs maybe 1/2 inch wide and long enough to swing down/up to hold the cluster. Nothing fancy or complicated.
kubes40 | -- 11-13-2012 @ 6:24 AM |
What did Ford use behind the 1940 dash to hold the instrument cluster in place? I know there's 4 studs on the back of the dash, but what sort of clamp/bracket was attached? Four of the small special washers depicted in the attached photo. They are approximately 1 1/2" in length, maybe 5/8" wide.
trell | -- 11-13-2012 @ 6:36 AM |
Thanks guys for the picture and the help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5413 |
