DEAN333 | -- 11-06-2012 @ 6:11 PM |
Does anyone know the trick to remove the ignition switch and lock cylinder on a 1964 Fairlane?? Thanks Guys! TIM CARLIG
trjford8 | -- 11-07-2012 @ 6:51 AM |
Tim, in the front of your cylinder you will see a small hole next to the key slot. Turn the switch over to the accessory position and then insert a wire or paper clip into the hole. As you push inward with the wire turn the key past the accessory position and it should pop out.
DEAN333 | -- 11-07-2012 @ 8:06 AM |
Sorry I didn't give enough info....this was a barn find with no key available. TIM CARLIG
Tom/SC | -- 11-07-2012 @ 11:56 AM |
Dean, I recently had this same problem on a 1963 Fairlane with only 30,000 original miles which I bought with no keys. I removed one of the front door upholstery panels, removed the door lock cylinder from the door,and had my key shop make a key to fit that cylinder. The key is the same code as the ignition switch. It worked for me! Good luck, Tom
DEAN333 | -- 11-07-2012 @ 12:44 PM |
Thanks Tom, will give that a try. Why didn't I think of that? Duh! TIM CARLIG
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5393 |
