MICHV8 | -- 11-04-2012 @ 5:35 PM |
I know the gas tank fuel line should be Bundy copper coated steel...are Bundy pump to carb lines available as well? Thanks.
ford38v8 | -- 11-04-2012 @ 6:38 PM |
Yes. If you have enough left from your restoration, use it. If not, be sure to specify year and application when ordering, as the exact bends are slightly different between some years. Alan
supereal | -- 11-05-2012 @ 9:37 AM |
You didn't say what year your car is. There are six different prebent pump to carb lines for '32-'48 listed on page 127 of the C&G online catalog. www.cgfordparts.com These come with new fittings included. Prebent is the way to go.
MICHV8 | -- 11-07-2012 @ 7:35 AM |
It's a stock 37 intake manifold with a later steel bowl pump to a Holley 94...so I looked online at C&G and would guess 81A-9369??? C&G lists that as 38-39 (maybe due to the Holley instead of the 97)
37 Coupe | -- 11-07-2012 @ 9:33 AM |
Jerry Grayson V8 club member in Georgia makes up copper coated steel fuel lines and carb lines. Tell him what carb and what fuel pump you are using. He is listed in roster but is on here and Fordbarn now and then.
supereal | -- 11-07-2012 @ 9:43 AM |
That number,81A-9369, is specific to the 94 carb. The other, 78-9369, fits the Stromberg 97. The intake manifold and the pump stand is the same, but the line to carb is different depending upon the carb.
Tom/SC | -- 11-07-2012 @ 12:01 PM |
Supereal, I have a question for you if you will please PM me at:toms40insc@bellsouth.net. Thanks!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5382 |
