rogbell | -- 10-21-2012 @ 8:22 AM |
Is the process to change the driven speedometer gear in a C-6 trans the same as for a C-4? Thanks.
trjford8 | -- 10-21-2012 @ 9:28 AM |
I would say yes if the cable assemblies are the same where they enter the transmission. If you have a Ford dealer in your area that has been in business for a long time they can probably give you a definitive answer. Also the early Mustang parts vendors could give you the correct answer. This message was edited by trjford8 on 10-21-12 @ 9:48 AM
carcrazy | -- 10-21-2012 @ 11:25 AM |
You can contact The Gear Box Transmissions, Inc at either www.thegearbox.org or 734-793-0727. They are a great source for transmission information and parts.
rogbell | -- 10-22-2012 @ 8:01 AM |
Thanks to both of you, appreciate the help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=5328 |
